ie7 issues
Thread begun 5/19/2010 5:57 pm by surfbouy | Last modified 6/24/2010 6:34 am by martingh.spencer409829 | 3413 views | 6 replies |
surfbouyBeta Tester
ie7 issues
I am having a ie7 issue with 2nd level menu dissapearing before it can be clicked on.
I understand it could be a quirks mode issue.
The site is www.noosasurfclub.com.au/
I have added a class to act as the heading in some menus but other than that I'm sure the code is straight out of menu writer.
Craig
PS I'm a mac user and if I test at browserlab I can't see drop down so I am flying blind. It is just feedback from the client..
Jimmy Wu
When I test on IE7 and IE8, I am able to navigate to the menus without any issue. Can you get a little more information on your customer's setup so we can do some more testing on it?
surfbouyBeta Tester
more info
Hi Jimmy,
Firstly thanks for the great support you guys offer.
The client is using windows XP and IE 7.0.5730.13
The issue is the dissapearing menu.
eg. corporate education >> Surf Programs >> CPR (this level is dissapearing when hovered over and is unnavigatable <-- if that is such a word)
Thanks again
Craig Jones
neilo
Hi Jimmy and Surfbouy,
Hi
The way the page is at the moment, IE7 is subject to the conditional statement stylesheet 'menu_ie8.css' in which the level-2 menu has a width of auto, which is good for IE8 - but no good for IE7 which requires a declared width (in px or em):
<!--[if IE ]>
<style type="text/css" media="all">
@import url("http://www.noosasurfclub.com.au/CSSMenuWriter/cssmw/menu_ie8.css");
</style>
<![endif]-->
So you could either:
Adjust the menu_ie8.css to account for IE7's shortcomings and change the rule at or near line 135 for ul#cssmw ul.level-2 > li > a { by changing the width from 'auto' to 200px (to take into account the longest menu item - 'Advanced Resuscitation Techniques) - but this widens all level-2 menus in IE8 as well as IE7,
or:
You make use of the menu_ie.css by changing the <!--[if lte IE 6]> conditional statement to include IE7, - <!--[if lte IE 7]> between the head tags on each of your pages (can be done by adding it to your template, and updating pages based on that template). Then change the ul#cssmw ul.level-2 > li > a { on the menu_ie.css to a width 200px, instead of auto.
You might also have to correct the path for the menu_ie.css in the the <!--[if lte IE 7]>.
surfbouyBeta Tester
thanks
Thanks works a treat
Jimmy Wu
Thanks for pointing that out neilo.
Great to hear its working for you Surfbouy. If you run into any additional issues, feel free to open a new thread.
An article may be helpful for you
hey, Guys it looks you have shared a very helpful information for users, in case you face a problem with IE again and may be the answer of your question can be found here: How_to_Fix_an_Exe_Error__Repair_Windows_Errors_in_a_Click__1.html
