SQL syntax on sort
Thread begun 5/19/2010 11:08 am by frank262985 | Last modified 5/24/2010 6:50 pm by Eric Mittman | 3023 views | 5 replies |
frank262985
SQL syntax on sort
Sorry to be such a bother.
When I have the multicolumn sort set up and just before adding the Sort Server Behavior all is well and shows fine in the testing server.
When I add this behavior I get the following error - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'ASC, ASC LIMIT 0, 1000' at line 1.
I'm in Windows 7 and DataAssist 2.07 beta.
The server markup for this sort is as follows -
//WA DataAssist Sort (Copyright 2007, WebAssist.com)
//Recordset: WADAOwner_List;
$WADA_Sort_1 = new WADA_SortObject();
$WADA_Sort_1->DefaultSort = "";
$WADA_Sort_1->ColumnList = "".((isset($_GET["sort"]))?$_GET["sort"]:"") ."^SuiteNum^Last_Name";
$WADA_Sort_1->SortOrderList = "Ascending^Ascending^Ascending";
$WADA_Sort_1->ToggleOn = true;
if ((((isset($_GET["sort"]))?$_GET["sort"]:"") != "")) {
$WADA_Sort_1->SetToClause = $WADA_Sort_1->getDefaultSetToClause();
if ($WADA_Sort_1->ToggleOn && isset($_SESSION["WADA_OrderClause_Owner_List_Results"])) {
$WADA_Sort_1->ToggleClause = $_SESSION["WADA_OrderClause_Owner_List_Results"];
else if (isset($_SESSION["WADA_OrderClause_Owner_List_Results"])) {
$WADA_Sort_1->SetToClause = $_SESSION["WADA_OrderClause_Owner_List_Results"];
$WADA_Sort_1->initialize();
$_SESSION["WADA_OrderClause_Owner_List_Results"] = $WADA_Sort_1->SetToClause;
I've attached the form I filled out to produce this code.
It looks like you have the ASC twice in your query. In your original recordset that is on this page are you filtering by a column in ascending order? Maybe you are specifying to sort by a particular column in ascending order within the DataAssist Search server behavior. If this is the case you will need to remove it from the other location it is occurring in first. Please check this out and try updating the query or the search server behavior and let us know the result.
frank262985
Sort problem changed
I had made sure there was no sort set up before begining this process. The only change I made from the last post was that I left the RecNum field as being the primary key which before I had switched to Suite#.
Once again I believe I followed all the correct procedures but the result is different.
I now get - Unknown column 'Ambeau' in 'order clause' - which is the entry in the first record for Last_Name.
The Sever markup is now as follows -
I'm sorry about this as I seem to get different results by changing something I'm not aware of.
The database has 5 fields,
RecNum (Primary key)
SuiteNum - not indexed
Last_Name - not indexed
FirstNames - not indexed
Phone# - not indexed
My report uses all of them except the RecNum
I'm a little confused by the update that was made to your post where it says that it is now working. Are you still having problems with this or have you resolved the issue? If you are still having trouble with this please post back and let us know what you are hoping to accomplish as the end result and include a copy of this page as well as the exported table that you are searching. I will try to use your own files and data to help determine what is going wrong.
frank262985
Problem resolved
Thanks so much for your help.
The issue has been fixed and this thread can be closed.
Frank
Ok, glad to hear that. Let us know if there is anything else.
