Migration of old categories to new
Thread begun 5/18/2010 6:03 pm by msjj000 | Last modified 6/02/2010 2:14 pm by Jimmy Wu | 4555 views | 8 replies |
msjj000Beta Tester
Hi WA,
I've migrated a site form PS2 to PS3. We have now taken advantage of the new side menu features and created sub categories. Here's what happens. We create the new categories and sub categories and apply the existing products to the new categories/sub-categories. Even though the un-select the old category the item still appears in it. Is there something that we should be looking at or doing to not have this happen?
Thanks, Mark.
Jimmy Wu
I haven't seen this behavior before. Can you try removing the product from the category without adding any subcategories first and see if that works? You can set the product to have no categories by clicking on the categories while holding ctrl (on pc) or command (on mac). Check to see if the product shows up in the category or not.
The next thing to check would be to go into the database and check the ps3_productcategories table. Do a search on the ProductID of the product you're changing the category for (you can find this in the ps3_products table). Then you would get a list of the Ids of the categories that the product is added to. You can check which categories these are by looking in the ps3_categories table. This way you can check if the product is added to the undesired category. A workaround to this issue would be to remove that entry from the ps3_productcategories table and it won't show up in that category anymore.
msjj000Beta Tester
Hi Jimmy,
Thanks for the feedback.
The behaviour only happens when there is an advanced option on the item like size or color for example. Products without this don't appear to have a problem.
For products with advanced options I can remove the product from any category and it doesn't appear in the new category. Once I add it back in it then shows in both the old and new cateogory. The product always remains in the old category. If you remove the product from all categories and then remove the category it deletes all the products that were included in the old category that came across from PS2 into PS3.
I'm not sure if I am on the same page with looking at which categories an item is attached to. Could I have a field missing? I can't see a field that has multiple categories listed in it.
In the ps3_productcategories table product ID 707 is attached to category ID 8 and 115 and productcategory ID 1776 and 1777 and product ID 708 is associated with 10 and 625 respectively. It is Product ID 707 and 708 that are related as the different size of the item.
There's quite a few items in teh database so manually going through the table isn't an ideal option - more of a last resort.
Thanks, Mark.
Jimmy Wu
Deleting the category shouldn't be removing any products. Does deleting new categories also have this effect?
msjj000Beta Tester
Hi Jimmy,
On new categories it all works fine. Looks like it only affects categories migrated from PS2 with advanced options (not those without advanced options from PS2)
Mark.
msjj000Beta Tester
Hi Jimmy,
I have now also upgraded a sister site and l can't take products "offline" - uncheck make available online. How are you going with this behaviour?
Thanks, Mark.
msjj000Beta Tester
Hi Jimmy,
This issue across PS3 and migrated data categories is starting tio cause me a headache - can you please suggest a where to from here?
Is it helpful to get an extract of the database or relevent pages?
Mark.
msjj000Beta Tester
Hi Jimmy,
Just to go back to your earlier comment. I've created new catagories, associated the product there also then I have deleted the old category that came across from PS2 from the ps3_categories table - that seemed to work.
Could this create a problem done the track or is this a safe thing to do?
Thanks, Mark.
Jimmy Wu
That should be fine if the products are associated correctly to the category that you want them to be added to.
Is there anything special about the categories that are migrated from PowerStore 2 to PowerStore 3?
