Admin login problem
Thread begun 5/18/2010 4:44 pm by zanimul379168 | Last modified 6/08/2010 10:51 am by Jason Byrnes | 6901 views | 9 replies |
zanimul379168
Admin login problem
I've searched the forum for others with this issue, came across one that indicated the issue had to do with the php.ini file. I've tried the page.1 and page.2 as suggested and it appears to be fine. Yet, after quadruple checking the id and password correct, I still cannot login. No error message and I'm thrown back to the login page.
Help!!
First, lets check that session management is functioning properly on your server.
See the following thread for a sessionTest.php file. upload this file to your server to test for working sessions. If the test fails, you will need to contact your host to have them look into the issue.
zanimul379168
The session id does not change when using the sessionTest.php that is listed in the other thread. Where to now?
but does the session value change from test to NULL when clicking the second link?
can you post a link to the sessionTest page so I can see the results.
zanimul379168
sessionTest.php
Session Test does start out as NULL, but changes to test. Regardless the link above is what you want to see.
login.php
support391307
Same issue
This is terrible...
have you tried using the sessionTest.php page from the following thread:
showpost.php?p=23826&postcount=2
what is the result?
once uploaded, please provide a link to the sessionTesrt.php page.
support391307
No session issue...
J-kproductions.com/sessionTest.php
login.php
