Problem with Server Behavior Trigger form
Thread begun 5/18/2010 12:33 pm by frank262985 | Last modified 5/19/2010 9:14 am by Jason Byrnes | 2861 views | 5 replies |
frank262985
I have been working through the column sort fearture and have got to the point where I apply the Sort server behavior. Once I've put in the 2 items to be sorted the form will not allow me to go down tothe OK button. The slider does not go that far and I can't re-size the box to see it.
I've attached what it looks like.
How do I get around this one?
I'm using the latest DataAssist 2.07 beta but it did the same thing in 2.06. I'm using Windows 7 32 bit.
try changing your screen resolution to something that is taller.
It looks like the currant screen resolution does not have enough height to properly draw the Sort dialogue box.
frank262985
Originally Said By: frank262985
I have 2 monitors, both set at maximum resolution, 1 is 1280 x 1024 and the other 1680 x 1050. The form shows the same on both of them and doesn't fill the screen height.
I have encountered a similar problem if the DPI setting is changed from normal to something larger. Have you changed the DPI settings?
frank262985
BINGO!
I had changed the dpi to 125%. I changed it back to 100% and all is OK.
excellent, glad to hear it is working.
