use KFM on html forms
Thread begun 5/18/2010 10:37 am by victor278184 | Last modified 5/20/2010 6:49 am by Jason Byrnes | 3030 views | 4 replies |
victor278184
hello, as i see on HTML Editor, i could use KFM when i click on "Browse Server". Now i would like to know if i could do the same thing on html form..
if i had form design like.. Product Image : __________ [Browse Server]
when i click browse server .. KFM appear and return seleteced image filename (with path).
is it possible ?
It is possible.... but requires a little coding by hand currently.
If you had a button with id="browsebtn" and a text field with id="textField"
You could add code like:
<script>
window.addEvent('domready', function() {
var el=document.getElementById('browsebtn');
el.onclick=function(){
window.SetUrl=(function(){
return function(value){
document.getElementById('textField').value = value;
})(this.id);
var kfm_url='../../../HTMLEditor/Editor/plugins/kfm/index.php';
var kfmwindow = window.open(kfm_url,'kfm','modal,width=600,height=400');
kfmwindow.focus();
</script>
Yes, i believe the KFM can be used in stand alone forms.
See the KFM website for details on how to accomplish this:
kfm.verens.com/
victor278184
Hello, thanks for your reply,
could i give you a live link to check (out of this forum of course since it's a live site)... i tried and tweak the code without sucess
Secondly i notice i'm able to directly open KFM via url which can be security flaw..
is there anything i could do to prevent this (maybe use security assist module)
The stand alone KFM is not really something wee can offer a lot of support for, If you are having problems implementing it, you should post in the KFM support groups.
