Storing server file name in session
Thread begun 5/18/2010 6:50 am by rob75685 | Last modified 5/18/2010 9:20 am by rob75685 | 1661 views | 2 replies |
rob75685
hi there
I'm having problems storing the uploaded server file name in a session.
I've successfully set up an upload page here:
prodstep2.php
If you upload an image it refreshes the page showing the image and the server file name underneath it.
Here's my session code, can you see what I've done wrong here?...
if($WA_DFP_UploadStatus["WA_UploadResult1"]["statusCode"] == 1) {
$_SESSION["newimage"] = "".$WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"] ."";
many thanks
Hard to say without seeing the code.
My First guess is that the Set Session Value code is before the Upload image code.
Make sure the Set Session Value code comes after the upload image code or the server file name variable will be set when the session is set.
rob75685
hi Jason
Yes that works putting the session value after the upload image code
thanks for your help
