Thumbnail and if file_exists : View cart
Thread begun 5/17/2010 1:07 pm by MikeH | Last modified 5/17/2010 4:06 pm by MikeH | 1999 views | 3 replies |
MikeH
Hi
Is there a way in the View_Cart if a thumbnail doesnt exist a genericimage is shown?
The code I am trying to use is:
if (file_exists($eCart1->DisplayInfo("Thumbnail"))) {
<img src="<?php echo $eCart1->DisplayInfo("Thumbnail"); ?>" alt="" width="95" class="eC_ProductThumb" />
} else { ?>
<img src="images/noimage.png" alt="" width="95" " class="eC_ProductThumb" />
As Im am testing this $eCart1->DisplayInfo("Thumbnail") it fails the test everytime any way around this?
It is purely that refrence that is failing as used outside of ecart with a normal recordset refrence this code works.
Any ideas?
Mike
tom92909Beta Tester
You could add a logical field to your products table that indicates if the thumbnail exists and same for a large images too. Storing a zero for NO & a one for YES in your indicator field. You could probably make that default to NO, and update to YES when a successful upload is completed for each record.
if ($row_getProduct['thumbnail_exist']==0) {
   <img  src="images/default_thumb.jpg" width="95" border="0">
} else {
   <img  src="images/<?php echo $row_getProduct['thumbnail']; ?>" width="95" border="0">
MikeH
Hi
Thanks for the reply. Thats basically what |I have done on the rest of the site. Its just in the actual "Display Cart" section you get the binding
which contains for example - ../images/thumbs/yourtumb.jpg
Problem is
if (file_exists ............
Does not seem able to use that binding it always fails the test.
I want to cover all bases and actaully check if the file exists not just the name in the DB just in case the physical file is not there.
Mike
MikeH
Hi
Sorted it. Chenged my code to this and that now does check if a physical file exists.
if (file_exists($_SERVER{'DOCUMENT_ROOT'} . "uploaded_images/thumbs/"  . $eCart1->DisplayInfo("Thumbnail"))) {
                <img  src="../uploaded_images/thumbs/<?php echo $eCart1->DisplayInfo("Thumbnail"); ?>" alt="" width="95" class="eC_ProductThumb" />
} else { ?>
Thanks for your help.
Mike
