Changes to UE behavior don't save correctly
Thread begun 5/17/2010 12:02 pm by Roxana | Last modified 5/18/2010 4:42 pm by Dani Chankhour | 2584 views | 4 replies |
Roxana
I wanted to save a change to the editing part of the UE behavior. So I opened the behavior, clicked the body tab, then "edit in DW" and made the change.
When saving I get this error message:
"While executing onLoad in WAUE_afterSave.htm, a JavaScript error occurred."
When I hit OK, I get the same error message again. And when I click OK again, there is no more error message, but the WAUE file stays open, and I have to close it manually. The temporary file "checkout_success_germany_WAUE_HTML_WA_Universal_Email_germany.php" does not get deleted.
The change I made however does not stick. When I do the same process again, the change does stick, but it does not only change the body of the German success page, but also completely replaces the European body. Each of these pages has it own dedicated behavior and body. The third behavior and body for the international success page are not affected by the change.
Roxana
I don't exactly know what happened, but I opened only the German success page, and now the behavior seems to be working. I rather not touch the files now, that they are working, but could you explain the error message?
Dani Chankhour
I have seen this error message before, could you please tell me what version of UE you are using?
Roxana
Hi Dani,
I am using UE 3.0.7.
I have to add, that the error message does not appear for the international successpage.
Throughout the day I had tried countless times to save changes to one email body, but it either didn't stick or was saved as well to the body of the other email behavior. At some point of the process of trying and reloading the good copy from the server, it suddenly worked.
Dani Chankhour
Are you getting the error message with the Universal Email on that page or does it happen on other pages. As a test can you try to apply universal email to a blank page and see if you get the same result.
If the error message is specific to that page, you can delete the checkout_success_germany_WAUE_HTML_WA_Universal_E mail_germany.php manually and see if that clears the issue.
