eCart 5 JavaScritp error
Thread begun 5/17/2010 6:43 am by vmartinez310076 | Last modified 5/18/2010 11:51 am by Eric Mittman | 2328 views | 3 replies |
vmartinez310076
When I try to make a change to an existing eCart in eCart 5, I keep getting the same error message;
"While executing onClick in WA eCart Object.htm, a JavaScript error occurred."
I have attached a screen shot of the error message.
Any help will be appreciated.
Have you tried deleting the cache file to see if that clears up the error? Here are the steps that you can take for this:
If you continue to have this problem after clearing the cache file there might be a problem with your configuration. If this is the case you will need to follow these steps to undo any corruption that may have taken place.
showpost.php?p=12293&postcount=2
If you continue to have these errors after trying both of these please let us know so we can look into this further
vmartinez310076
Thanks for the help. I will try it and hopefully it will fix it.
Thanks,
Vince
Let us know if this does not clear up the problems so we can look into them further.
