PowerGallery IE7+ Issue
Thread began 5/17/2010 4:49 am by contact319325 | Last modified 5/18/2010 11:51 am by Eric Mittman | 1143 views | 3 replies |
contact319325
I like the Powergallerie very much and created a site with multiple galleries, using greybox to load them:
www.villabonita.ch
Everything works beautyful in every browsers except IE7+
There get errormessages. but not all the time if you click arount sometime it works somtimes not. that's very strange. Has anyone an idea what that could be?
Thanks for any help
This is just a js warning that you are seeing? Does the gallery stop working for you when this occurs? It looks like just a simple browser js warning to me, most browsers handle js and other client side code a little differently so if you are not noticing any functionality issues then it is not something that should be of concern.
You can go into the settings of your browser and adjust the warnings to that you are not alerted everytime there is a js warning occurring.
contact319325
Hi Eric,
Thank you for your response.
No, it's not only a warning the gallery stops working and pictures after that messages are not loaded. And it is only in IE7+ IE6 it's working fine, firefox opera safari too.
Does it also work in IE8 correctly? I was not able to get the error to happen for me. I tried visiting a couple of the galleries that I saw on the page you linked to and did not see this result.
If I were able to reproduce the issue we would have a better chance of determining what the problem may be. Are there a set of steps that you can take to get this error to occur more consistently? Also, have you modified the gallery with any additional js code or make any changes to the existing js code?
