More Y axis labels in chart.
Thread begun 5/17/2010 3:02 am by Mark Kujoy | Last modified 5/18/2010 7:45 am by Jason Byrnes | 2273 views | 3 replies |
Mark Kujoy
Hi.
Im plotting temperature / time data in a line graph. Temp is on the Y axis. Temp range is 0 to 250 °C. On the Y axis its only showing labels for 0°C, 125°C and 250°C. I would really like to show labels for every 10°C on the Y axis.
All data is Dynamic and php.
Can this be done?
Mark
In design view, click the WebChart flash element to select it.
In the property inspector, click the Edit In XML Editor button
In the XML Editor window, select the yaxis node then click the plus button and select "ticks"
this will add a ticks tag to the chart XML in the yaxis node:
<ticks />
edit the ticks tag to add a number property wit the total number of ticks you wish to show. for example to show 14 ticks:
<ticks number="14"/>
Mark Kujoy
Thanks Jason.
Exactly what i was looking for.
Glad to hear it is working.
