Form Builder and Security Assist
I have CSS Formbuilder, to realize which for a Plugin custom I around a Login?
If you are new to CSS Form Builder you should start out by checking on the support page, here is a link:
css-form-builder/
In here you should start with the getting started guide. There is an option for a login type of form in the form builder presets so you can use this for a login form. This will only create the form though, to make it work with your db and users table you will need to make use of Security Assist. If you use this tool on the login form you can link it with your users table.
Thus I need to provide Security Assist around functioning Login?
Regards
When you use Security Assist the wizard will create a set of pages for you including a login, registration, and update page. Once you have created the pages with Security Assist you can then modify them to fit your needs with form builder.
Here is a link to the Security Assist support page for more info:
securityassist/
You could also manually create the forms first, then apply the Security Assist server behaviors to these pages.
