Session variable in file path causes error when editing server behavior.
Thread begun 5/16/2010 11:45 am by Mikel Jones | Last modified 5/17/2010 11:40 am by Jason Byrnes | 2643 views | 3 replies |
Mikel Jones
Repro Case: In Dreamweaver go to the server behaviors pannel and add the DFP upload server behavior.
Fill in standard correct values for the upload and go to step 2.
Fill in standard correct values except append a session variable to the upload folder path like the following example.
Example: "../images/Users/". $_SESSION['UserID'] ."/"
Result: The value will be accepted but the upload server behavior will be INCORRECTLY written in the code and cause a PhP error when executed.
'UploadFolder' => "\"../images/Users/\". $_SESSION['UserID'] .\"/\"",
Note the backslashes in the result value above.
if you correct the code so the value is correct...
'UploadFolder' => "../images/Users/". $_SESSION['UserID'] ."/",
The file upload will work correctly however an error dialog pops up whenever you attempt to edit the DFP upload server behavior:
"It appears that one of your server-side values is improperly coded. Please check this interface for inconsistencies."
Also the value when checked is now written incorrectly in the editor.
Note the missing quotes on both ends of the string.
If you finish the server behavior the value will again be incorrect in the code and again cause a PhP error.
This is not a bug.
The File folder entry is a string. To add a php value, you must enclose it in php tags.
If you where to click the lightning bolt and select the UserID session variable, the File name box would look like:
<?php echo $_SESSION['UserID']; ?>
you can then add the rest of the folder location around that:
../images/Users/<?php echo $_SESSION['UserID']; ?>/
this will cause the code to be entered corretcly as:
'UploadFolder' => "../images/Users/".$_SESSION['UserID'] ."/",
Mikel Jones
My bad.
Thank you.
No worries.
