The dang dwsync.xml files!
Thread begun 5/16/2010 5:31 am by msummers194171 | Last modified 5/17/2010 6:02 am by msummers194171 | 7668 views | 2 replies |
msummers194171
Uploading PCMS is such a drag with having to click through all of the "ignores" for the locked dwsync.xml files. Any way to avoid that?
neilo
Hi msummers,
You can disable synchronisation information (the dwsync.xml files) per/site in Dreamweaver. Open the site in DW and:
DW Menu bar > Site > Manage Sites > select your site > Edit > Advanced Tab > Uncheck the 'Maintain synchronization information' checkbox
Click OK to the info/warning box. This will disable synchronisation and also remove the existing dwsync.xml files. You can re-enable it (if you want to) later.
msummers194171
Oh - how obvious is that? Thanks a million!
