Flat Rate shipping for small and large items
Thread begun 5/15/2010 12:03 pm by i.edwards384429 | Last modified 5/18/2010 7:52 am by Jason Byrnes | 3065 views | 4 replies |
i.edwards384429
Hi
have a client who has just two fixed shipping fees one for small articles one for large.
I realise I can differentiate between small and large by assigning weights but how do I implement the shipping side
I have ecart but woulkd appreciate some hints
thanks
Ian
In the weight column, you could store the shipping amount for each item.
Then set the shipping rule to use:
trigger:
Total number of unique items in the cart > 0
calculation:
Based on column subtotal
subtotal of Column "Totalweight" "plus" "0"
i.edwards384429
update
Hi
thanks Jason, not sure I follow you but hey it's a learning curve. Watch this space
cheers
Ian
i.edwards384429
update
Sorry Jason
I clearly have not grasped your meaning.
If I open cart.php and then double click on server behaviour ecart and select the shipping tab I see
asps
ups
fedex
which I dont need
I assumed I delete these and the n select Add?
From there I'm lost is this not what you meant?
thanks
Ian
Yes, remove the shipping calculations that you don't need and create a new one.
When setting up shipping rules, there are three sections:
1) Name
2) Triggers
3) Calculation.
Set the name something like "Shipping Rate"
In the triggers selection, click the plus button to add a trigger.
From the select list of available triggers select "Based on total Number of unique items".
In the form below the select enter:
If the total number of unique items in the cart is ">" a value of "0"
In the calculations section, select "Based on column subtotal" from the select list of available calculations, and fill the form in as:
Subtotal Column of "TotalWeight" "Plus" "0"
