Flat Rate and Shipping Provider Options
Thread begun 5/14/2010 2:48 pm by mrobben375515 | Last modified 5/18/2010 7:45 am by Jason Byrnes | 5681 views | 11 replies |
mrobben375515
I need to have a flat rate (Local Delivery) and one UPS option for my customers. So it would be nice to have a drop down menu in the checkout section with both options. Can you give me a detailed step by step process of doing that or give me a link to a thread where you explain how to do this?
the keys to this working are:
1- Select it in a form element on the checkout page.
2- capture the selection in hidden form element on the confirm page.
3- capture the selection in a session variable on the confirm page.
4- Use the session variable value in the triggers for the shipping rules.
on the checkout page create your select list:
<select name="shipType" id="shipType">
<option value="Local Pickup">Local Pickup</option>
<option value="UPS">UPS</option>
</select>
on the confirm page, create a hidden form element of the same name, and set it to capture the value posted from the checkout page:
<input name="shipType" type="hidden" id="shipType" value="<?php echo((isset($_POST["shipType"]))?$_POST["shipType"]:"") ?>" />
Now add a Set Session Value server behavior.On the server behaviors panel, click the plus button and select eCart -> General Set Session Value.
Set the Name to shipType.
Set the trigger to any form post
for the value, click the lightning bolt and select the shipType form element.
Now in the eCart object, set the trigger for the local shipping rule to be Based on session variable value:
If the session variable "shipType" has a value "=" to "Local Pickup"
and set the trigger for UPS shipping to be Based on session variable value:
If the session variable "shipType" has a value "=" to "UPS"
mrobben375515
I followed your instructions but have a few questions. I wasn't able to get it working, and now when I go through the checkout process there's no shipping calculated. When you said to "create a hidden form element of the same name, and set it to capture the value posted from the checkout page" and then gave me the code to put into the page, does that php string in the code capture the value or did I need to do something extra.
Also, in a help session with jason he mentioned that eCart has some problems when you edit it. Do I need to go download any kind of fix? Right now I have USPS Shipping, FedEx Shipping, UPS Shipping, and then the two options Local Delivery and UPS Second Day Air as rules in the shipping tab of the eCart Object. Please tell me if this is wrong.
I've attached confirm and checkout pages just in case. Thanks for your time..
If you are adding in the additional shipping options, you should remove the existing UPS, FedEx and USPS shipping rules that came in power store.
the shipping rule is not working because you added the set session value serve behavior to the checkout page, it needs to be added to the confirm page.
also the hidden form element on the confirm page needs to be added with the rest of the hidden form elements down around line 1707
mrobben375515
Gotcha, thought I did it right. I made the changes and now I'm getting this error having to due with the new session variable...
Parse error: syntax error, unexpected T_STRING in /home/content/o/n/e/onetooneweb/html/confirm.php on line 19
I've attached the confirm.php page. Thanks again for the quick responses...
not sure how you got this code:
if((any form post != "")) {
but it needs to be changed to:
if($_SERVER["REQUEST_METHOD"] == "POST") {
mrobben375515
The Local Delivery flat rate option works now, but when I select the UPS option it doesn't calculate the shipping. The UPS shipping rule is set to "if session variable shipType==UPS" and calculation is "based UPS shipping quote value". I've attached the two pages...not sure what to change
try moving this code:
$_SESSION["shipType"] = "".((isset($_POST["shipType"]))?$_POST["shipType"]:"") ."";
down the page to be just before the doctype tag. probably a code order issue.
mrobben375515
Same thing, local delivery works...UPS doesn't. Any other ideas?
make sure that shipping is enabled in the Admin panel and that you have selected UPS. The ups shipping look up code is still dependent on what you set in the admin
Also send a copy of the WA_Store_Cart_PHP.php file
