currency change
Thread begun 5/14/2010 6:27 am by info376778 | Last modified 5/20/2010 10:50 am by Eric Mittman | 2500 views | 4 replies |
info376778
currency change
Hello, I own powerstore3
I have read all the entries in the forums, I have downloaded a pdf manual. Some changes took place in the powerstore script, but in the front page still the dollar is there.
also in the back end in the products page.
Please advise.
eshop
MikeH
This has to be one of the most frequent monas people have about PS.
I still say as WA are marketing globally they should have at least 3 versions to download once purchased:
US Dollars
UK Pound Sterling
EURO
They know where all the references to the currency are so it would make so much sense for them to take a few minutes to make these versions.
Either that or PS should have the currency in a settings file so its changed globally in an instant.
Just an idea.
Mike
tonygmg362159
You need to make sure that once you have done the changes as general you need to make sure that you look into the main source code and then change the dollar signs to pound signs. Do you have an url and maybe i can help identify the lines of code you need to change?
info376778
about currency
I would really appreciate your help.
These people are just amazing! Thay have some OK products, but I can see that support is way behind!
If we could know php ot things like that, we would not pay them for their solutions! What else can I say, I read many complaints about this matter. I can really accept your help.
here is the link.
eshop
These dollar signs are hard coded on the index.php page. To get rid of them open up this page and go to line the following lines to replace them:
174
<h4>$'.
187
<h4>$2
210
<h4>$'
221
<h4>$2
Are there any other areas where you are seeing the dollar sign instead of the currency you are using? I looked around a little and did not see any other areas myself. I know that there are some places that are not mentioned in the pdf document, I will forward this info so it can be added and if there are any other places I will note those as well.
