Javascript error when creating a new menu
Thread begun 5/13/2010 5:36 pm by surfbouy | Last modified 5/17/2010 9:46 am by Jason Byrnes | 2005 views | 3 replies |
surfbouyBeta Tester
I have just had some trouble with menu writer.
I removed it then re installed it but I am still getting the same error message when it tries to create the new menu
error generating menu (wa. generate.menu):
type error: MM.WA_createProcessingObject is not a
function
I can't seem to make a new menu no how....
Try deleting the Dreamweaver cache file from the users configuration folder.
surfbouyBeta Tester
thanks
I had already done this.
I may have not restarted dreamweaver.
I has worked this time...
thanks again
Yes, Dreamweaver must be closed when you delete the cache file.
I have seen some instances where you also need to reboot the computer and delete the cache file again for it to work.
Glad it is working for you.
