Log in options grayed out
Thread begun 5/13/2010 11:45 am by nickj | Last modified 5/14/2010 4:36 pm by Eric Mittman | 2957 views | 3 replies |
nickj
I'm building a new set of files on a new site and the "Log in options" are grayed out! Why, will I have to redo all the files once you tell me the trick?
Nick
Which login options specifically are you referring to? With most of our extensions you will need to have a page open that has been saved to the site. This is a main requirement for may of the server behaviors. Please describe exactly what you are experiencing in more detail so that we can help you get past the issue.
nickj
On an existing site
On an existing site I opened the security wizard to build the log in, registration ect. pages, when I got the to box which details the login page the "Log in option" were grayed out, these are the ones which ask if I want to be remembered on this computer etc.
There was a page open in the folder where I wanted the files to be located.
Nick
I see, thanks for the explanation. These options are disabled for you because you do not have the Coolies Toolkit installed. Security Assist will make use of the Cookies Toolkit to write out the cookie code to remember your login and auto login. Without Cookies Toolkit installed you will not have access to these options. If you are a library subscriber you should have this available to you in your download area if you would like to enable this feature.
