Sort error when used with Filter
Thread begun 5/13/2010 4:40 am by MikeH | Last modified 5/13/2010 1:23 pm by MikeH | 4582 views | 8 replies |
MikeH
Hi
I have been trying to use the DA Sort behaviour and have found it only works with a plain Recordset if you try to use with a Filter ie URL Parameter it cause a parse error when run in the browser.
So if you had a store product list that you displayed according to the category ie
SELECT *
FROM products
WHERE ProductCategoryID = colname
This would cause an error when used with the Sort Beahviour is there a workaround for this?
BTW the Sort behaviour works fine as this:
SELECT *
FROM products
Obviously not much use when needing to show only products etc from a certain criteria.
Mike
can you provide some more specifics?
What is the exact text of the error?
Can you send a copy of a page that has this problem?
MikeH
Hi Jason
I get a parse error as soon as I add the sort behaviour. Like I said it does not give an error when used with a plain recordset only when you add a URL Parameter to get filtered records.
As for the page I can but would rather email that.
Mike
what is the exact test of the error?
I need to know what the error is to be able to have any idea of the cause.
I dont have enough information to go by just knowing that it is a "parse error" This really doesn't tell me anything.
perhaps you could copy and past the error or send a screen shot?
Does the error occur in Dreamweaver or in the browser?
MikeH
Hi
error is very vague:
Parse error: parse error in C:\wamp\www\Prod_list_cat.php on line 102
Running on a local server as you can see.
The area its pointing to is:
mysql_select_db($database_tendringpets, $tendringpets);
$query_ProductListCT = sprintf("SELECT * FROM products WHERE ProductCategoryID = %s", GetSQLValueString($colname_ProductListCT);
setQueryBuilderSource($query_ProductListCT,$WADA_Sort_1,false);
$query_limit_ProductListCT = sprintf("%s LIMIT %d, %d", $query_ProductListCT, $startRow_ProductListCT, $maxRows_ProductListCT);
$ProductListCT = mysql_query($query_limit_ProductListCT, $tendringpets) or die(mysql_error());
$row_ProductListCT = mysql_fetch_assoc($ProductListCT);
2nd line is 102
Hope thats a little more useful.
I can email the page if required.
Mike
but it includes a line number which is very helpful, also tells me the error is happening in the browser, all important details to help me see whats up.
login.php
MikeH
Hi Jason
There is no Ticket available that I can see.
Logged out and in just in case but still nothing new.
Mike
Sorry, it is there now.
MikeH
Thanks Ive updated it.
Mike
