DWCS5 - Error initializing UI: typeObj has no properties
Thread begun 5/12/2010 6:36 pm by marco391960 | Last modified 5/26/2010 12:56 pm by Jason Byrnes | 3041 views | 3 replies |
marco391960
I have followed the instructions about deleting the DAT file, looked into several threads with the same error and still I don't see a straight solution.
Using DWCS5 with CSS Form builder 1.0.1
Please, help!
Thanks for your time.
We have not released an update to CSS Form builder to make it compatible with DWCS5.
We are in the process of evaluating each extension and will be releasing updates to each one to address DWCS5 compatibility.
marco391960
Form with CS3
Thanks Jason. So, if I work with CS4 instead of CS5 this should be fixed?
Thanks again.
Yes, it should work in CS4. Once the update for cs5 is released, you will be able to use it in CS5 also.
