Form Does not submit
Thread begun 5/12/2010 4:42 pm by michaelf0199272 | Last modified 7/19/2010 1:50 pm by Jason Byrnes | 7730 views | 21 replies |
michaelf0199272
I applied UE to the page indicated on the link. The form did not send when submit button is clicked.
Q: Is anything wrong with the way I had it setup.
serveareas.php
Yes, there is no opening form tag on your page.
The opening form tag tells the browser what to do with the information in the form when the submit button is pressed.
Without the opening form tag, the browser has no idea what should happen when the form is submitted.
michaelf0199272
I have made the correction that you identified. The form is still not getting sent.
Michael
change the forms action so that it posts to itself rather than the index page:
<form action="http://www.gbftacoma.org/" method="post">
<form action="serveareas.php" method="post">
michaelf0199272
thanks for your help. The form is still not sending. Please review errors below.
Warning: set_time_limit() [function.set-time-limit]: Cannot set time limit in safe mode in /misc/39/000/239/498/0/user/web/gbftacoma.org/serveareas.php on line 5
Fatal error: Call to undefined function microtime_float() in /misc/39/000/239/498/0/user/web/gbftacoma.org/serveareas.php on line 36
Michael
the error is being caused because your host has set the PHP processor to run in safe mode.
Universal Email cannot be used on a site that is running in safe mode. Safe mode must be turned off for Universal Email to function.
your host will need to disable safe mode.
michaelf0199272
Safe Mode has been disabled but I am still not able to submit the form as expected. Below is the error message that came up.
Thanks,
Michael
please send a copy of your serveareas.php page.
michaelf0199272
Here -- find attached the serveareas.php that you requested.
serveareas.php
Thanks.
When you apply universal email to a page, there are a couple of require once lines that get added to attach helper files:
<?php require_once("webassist/email/mail_php.php"); ?>
require_once("webassist/email/mailformatting_php.php"); ?>
these are missing in your serveareas.php page. Add those 2 lines at line 1 of your page, you may need to adjust the paths.
