Need to remove top nav bar
Thread begun 5/12/2010 3:41 pm by don327719 | Last modified 5/12/2010 5:39 pm by Jimmy Wu | 1417 views | 1 replies |
don327719
I am trying to remove the top nav bar from the Product_Results.php page however it will not let me touch the nav bar code there (I have made that file writeable). I have already taken it out of Main.dwt which I thought would update the rest of the pages, but it has not. Any help is appreciated.
Jimmy Wu
If you detach the page from the template in dreamweaver you can remove the menu. To detach a page from a template, you would go to the Modify->Templates->Detach from template menu. This would make the whole page writable, but modifying the template wouldn't affect the page. When you edit the main.dwt, does Dreamweaver ask you if you want to update all the pages? That is how it updates the pages if a template is applied to them. You could also edit it using a regular text editor like notepad and remove the menu there.
If you've made edits to the main.dwt, you can also apply the template to the page and the updates should be made on it.
