Multiple tax rules for Canada
Thread begun 5/12/2010 1:57 pm by nathan405389 | Last modified 5/13/2010 4:27 pm by Eric Mittman | 4664 views | 1 replies |
nathan405389
Hi there,
I am looking for some help in setting up mutiple tax rules for a Canadian based store. The province of the business charges a different rate to residing customers than if they were out of province. Any advice on making this work would be appreciated.
What is the province that the merchant is in and what provinces do they want to charge tax for? This is the first step, you must have clearly defined criteria to setup the tax rules.
Once you know exactly under what circumstances and the value to charge then setting up the tax rules will be very easy.
The general idea is that on the page that your checkout page posts to (usually the confirm page) you will want to add a 'set session value' server behavior. This server behavior will be used to create a new session variable, you can call it province. In this variable you will store the value from the posted province select list on the checkout form.
Once you have the province held in a session variable you can create the charge rules based on your criteria. You would first want to check for the session variable existing, then based on its value. You would have a rule like this for each province that you wanted a different tax rate applied to. For the amount you would base it off of the cart subtotal and multiply it by the decimal tax rate, so for 8.5% it would be multiplied by 0.85. Please post back with any additional questions that you have about this.
Maggie Simpson
Setting Session Variable
I have created my cart with the tax rule specifically for the state in which our business is located, where if ship to address is located within our state, then state sales tax is charged. This tax rule functions perfectly.
We also have nexus in three other states based on our delivery routes. Can I add the tax rules for these states in eCart1_PHP.php based on if and else if statements? Has the session variable in confirm.php (discussed above) already been created due to my original state tax rule? Sorry, I think I am just needing a little more clarity as to variable tax rules... thank you
the shipping state is stored in the eCartCheckoutForm_shipping_state_province session variable.
you can set up different tax rules for each shipping state. in the trigger section use the Session Variable exists and Based on session variable value to set up the conditions to trigger that tax rate.
so you would set one rule for one shipping state
another for a different shipping state and so on.
the triggers will apply the rule only if the conditions are met causing an If else scenario.
Maggie Simpson
Worked perfectly to set the tax rules based on session variable exists and is equal to state value. Thank you! Now I have to define further based on city and/or county. I am assuming ecart does not limit the number of tax rules that can be created?
nope you can create as many rules you need.
Maggie Simpson
Jason, you have been so helpful, thank you. A couple more questions regarding details for coding the tax rules...
I have coded different tax rules based on cities within certain states. Am I correct in my coding per the following example?
//eCart Rule
function WAEC_eCart1_Nebraska7SalesTax() {
$totalTax = 0;
if (true && ((isset($_SESSION['eCartCheckoutForm_shipping_state_province'])) && ((isset($_SESSION['eCartCheckoutForm_shipping_state_province'])?$_SESSION['eCartCheckoutForm_shipping_state_province']:"") == "NE") && ((isset($_SESSION['eCartCheckoutForm_shipping_city'])?$_SESSION['eCartCheckoutForm_shipping_city']:"") == "Ainsworth") || ((isset($_SESSION['eCartCheckoutForm_shipping_city'])?$_SESSION['eCartCheckoutForm_shipping_city']:"") == "Albion") || ((isset($_SESSION['eCartCheckoutForm_shipping_city'])?$_SESSION['eCartCheckoutForm_shipping_city']:"") == "Alliance") ||
and so on...
for all the cities within Nebraska that have a 7% tax rate? I am thinking that I set up the criteria correctly so that it identifies if the shipping_state_province variable is equal to "NE" AND the shipping_city variable is equal to one of many values (a OR b OR c), then assess this tax rate...
Also, how picky is the rule based on how people fill out the form with capitalization for their shipping cities? If someone fails to capitalize their city, will it not meet the rule and therefore not have tax assessed on the purchase? Thanks. Sorry to be such a headache.
Yes, that is correct, that rule looks like it should work
the tax rule is case sensitive.
you could edit the code to set the session variable on the confirm page:
if (!session_id()) session_start();
if(
$_SERVER["REQUEST_METHOD"] == "POST")     {
$_SESSION["eCartCheckoutForm_shipping_city"] = "".((isset($_POST["shipping_city"]))?$_POST["shipping_city"]:"")  ."";
to convert the string to lower case:
if(
$_SESSION["eCartCheckoutForm_shipping_city"] = "".((isset($_POST["shipping_city"]))?strtolower($_POST["shipping_city"]):"")  ."";
and use lower case in the tax rules to work around it.
Maggie Simpson
Do I also need to establish that the eCartCheckoutForm_shipping_city session variable exists before going on to identify all of the OR conditions for each city using that tax percentage?
yes, your first 2 conditions should be session exists to check that the city and state sessions are set before checking their value.
