Iframe and SagePay
Thread begun 5/12/2010 1:42 pm by Badger | Last modified 5/17/2010 2:05 pm by Eric Mittman | 4707 views | 5 replies |
Badger
Iframe and SagePay
Hello
I'm using SagePay's VSP server solution with eCart5 and just need to clarify setting up the iframe on our website so it appears the customer doesn't leave the original site. Note: When it's all working properly we'll be copying the files to a secure folder with a SSL cert and moving from "test" to "live", meanwhile:
SagePay support have helped identify where to put the code required as Profile=LOW.
It's on the page: Protx_VSPServer_PHP.php
The code to be added under "Currency" on line 78 is:
$postVals .= "&Profile=" . "LOW";
The iFrame should then be in the page checkout_notify.php and look like this:
<iframe src ="NextURL" width="770" height="550">
<p>Msg displayed if iFrame not supported</p>
</iframe>sit on the page:
but it's not working as some code is causing it to go to a failure page BUT SagePay are seeing a successful transaction.
So the question is what do I need to change on the checkout_notify.php or Protx_VSPServer_PHP.php that allows the iframe to be seen as the NextURL.
Lastly, how do I change the email notification to be sent after payment is confirmed?
Thanks guys
Badger
I've updated this thread with a fix to part one (profile=LOW). Just need help with getting the iFrame to be seen as the NextURL
I'm unsure of the proper way to use an iframe on this page, if you still have your ticket opened for this issue you should update it with this info so that you can get this part worked out. Since there has been so much other work done with the Sage Pay in your ticket I think it would be best to work this out there.
Badger
Will do. Thanks
Badger
Did that and was told to come back here. What happens now?
Sorry for the back and forth on this, I have opened another new ticket for you on this issue so we can look into it further.
