Working on Multiple Shipping Types
Thread begun 5/12/2010 1:39 pm by mrobben375515 | Last modified 5/28/2010 5:02 pm by Eric Mittman | 5725 views | 12 replies |
mrobben375515
I've been trying to search the forums on how to give customers multiple shipping services from UPS. I was following this one (showthread.php?t=12276&highlight=shipping+options) and Eric Mittman had said to insert the drop down menu using the snippets into the form and then "Once you have added the services select list you can use the lightning bolt icon to select this form element for the service type in the shipping quote server behavior on the confirm page."
I've looked in the confirm page and haven't been able to find the shipping quote server behavior. Is it in another server behavior like the ecart object or something? If that's all I need it should be an easy fix. Please let me know what else I might need to do after that. Thanks
i.edwards384429
update
Hi
I suspect that to add that functionality you will need access to some extensions such as ecart. PS3 is designed as a standalone module which can be altered by using extensions (which are not free)
HTH
Ian
mrobben375515
I have eCart so whatever I need to do I can do it...
You should be able to follow along with the steps listed in the thread you linked to. The server behavior is called 'eCart UPS shipping(WA_Store_Cart)' on the confirm page, there is one of these for UPS, FedEx, and USPS on the confirm page.
mrobben375515
There wasn't a Server Behavior for the UPS. There was one for the Fedex and USPS. So I created one, but I don't see the UPS_Service lightning bolt in the ecart_checkout_form to select it as the shipping method. So created a binding for the UPS_Service and selected it as the method. When I uploaded the pages and went through the checkout I got this error...
Fatal error: Call to undefined function WA_eCart_UPS_SetSessionDefaults() in /home/content/o/n/e/onetooneweb/html/confirm.php on line 497
mrobben375515
Here's the confirm page as well...
You will first want to revert this page back to it's default state before you were getting this error. Once you have it back to normal you can add in a couple of things to help you with this. The first thing that you need to add is the form data from the checkout page. To do this go to bindings > form data, in here select the checkout page. This will get the form bindings for the checkout page on your confirm page for you.
Once you have the bindings available you will want to add a set session value server behavior from Server Behaviors > eCart > General > Set Session Value. Give the session variable a meaningful name, the for the value use the lightning bolt icon to select the service type select list from the checkout form.
Finally when you modify the shipping quote server behavior you will update the service type to use this session variable that you just created. You will need to get the page back to it's default first. Then you can add the changes to the page one at a time.
mrobben375515
Now when I go through the checkout process the shipping calculates for whatever method I choose, but it won't allow me to checkout. When I hit checkout on the confirm page, it takes me to the checkout_failure page. This has happened several times and with different credit cards. The authorize.net is not in testing mode and the shipping is enabled. Maybe I don't have something set up in eCart right. I've attached the checkout and confirm pages and WA store cart page...thanks
If you are getting to the checkout failure page after seeing a successful shipping quote then the problem you are experiencing is most likely with the payment gateway.
You say that you are using Authorize.net correct? If so you will need to print out the full request and full response for the transaction on the checkout failure page. You can do this by adding the following code into your checkout failure page where you would like to see the info:
require_once("WA_eCart/Adv_CO_Scripts/AuthNet_PHP.php");
?>The full request is: <?php echo(AuthNet_Result("Full Request")) ?><br/><br/><br/>The full response is: <?php echo(AuthNet_Result("Full Response")) ?>
If you can't determine what the problem is with this info post back with it so we can take a look, make sure to remove any sensitive details like login or credit card info.
mrobben375515
It didn't post anything. It said..
