Map Page shows blank in live view
Thread begun 5/12/2010 1:22 pm by biverson407110 | Last modified 5/17/2010 9:45 am by Jason Byrnes | 3663 views | 5 replies |
biverson407110
In live view, map is blank but google navigation tools are shown but do not work - i've double checked all instructions and can get nowhere on this issue.
when a page displays blank in the browser, it is a sign that a php error is occurring but error reporting is turned off.
Add the following code to your page at line 1 to turn error reporting on:
error_reporting
(E_ALL);
you may need to view source on the page in the browser to see the error.
biverson407110
I get an error message in brower
"The website needs a different Google Maps API key.." Having done that to no avail, what do I try now.
tnx
make sure there aren't 2 instances of the line that sets the api key:
<script type="text/javascript" src="http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAvZMU4-DFRYtw1UlTj_zc6hT2yXp_ZAY8_ufC3CFXhHIE1NvwkxQcT1h-VA8wQL5JBdsM5JWeJpukvw">/*wagmp*/</script>
When generateing the api key, make sure you using only the domian name:
mydomain.com
and not adding in the page name:
page.php
biverson407110
reply - still not working
i've followed all the steps in a completely new pg with the same result. Now what? Still no luck.
please post a link where I can see the problem occur.
