Portions of map are transparent
Thread begun 5/12/2010 3:38 am by karola354883 | Last modified 5/12/2010 9:32 am by Jason Byrnes | 1882 views | 1 replies |
karola354883
I'm using the map on a business listing page for a site under development.
LocalSavings.cfm
You'll see that when the text bubble appears it makes a mess - the underlaying text is visible.
I have the map in a DIV with a z index of 100. Tried 10, 0, 10,000 - does not matter. The text in the table three layers down shows through. Tried different color and image backgrounds for the DIV's. No help there. Tried remming out the line for the openinfowindow line - that killed the entire map.
I'm using dynamic data - that works perfectly. Ideally, I'd like to just dump the text bubble altogether. But I'd still like to solve this. It always happens when I display the map in a CSS div popup.
The problem only shows up in IE. Works fine in FireFox and Chrome.
the issue is caused by the filter: alpha(opacity=100); setting in the styles/dmxpopup.css on the dmxWindow selector
.dmxWindow
position: absolute;
visibility: hidden;
top: 0;
left: 0;
height: auto;
width: auto;
background-color: #fff;
overflow: hidden;
border-top: 1px solid #dedede;
border-left: 1px solid #ccc;
border-right: 1px solid #ccc;
border-bottom: 1px solid #ccc;
z-index: 50000;
-moz-opacity: 1;
opacity: 1;
-moz-box-sizing: border-box;
Remove the opacity setting to fix the error.
the simple way to hide the info balloon is to enable driving directions in the pro maps wizard, but leave the starting address blank.
karola354883
This post has been deleted.
