CSS Form Builder
If I want to provide a form for contact with CSS Formbuilder, the path is required to the Actionpage. Where do I find the Actionpage?
Best Regards
Best Regards
I am not totally sure I understand your question but I will take a stab at it.
The action page is arbitrary - it's simply the page that will process the form after the submit button (or other trigger) is pressed.
Many times, developers use the exact same page that the form is on for the processing using PHP code at the top that determines if the submit button has been pressed and then processes the information and then redirects to another page after the processing.
For the action page, it would be set to nothing if you just want to use the page your form is on. If you want to handle the processing on a totally separate page, then you need to specify that page in your action page dialog.
Regards,
Brian
If I with CSS Formbuilder a form for contact provide must I a contact indicate where the form am sent away. The email must be indicated, and I do not know where? Please give me a Hint?
Regards
CSS Form Builder does not have capability to send out emails, you will have to create a form using CSS Form Builder and then run Universal Email to set up the emailing behavior after creating the form. In the Universal Email wizard, you will specify the from email address there.
Thanks for the answer, if I correctly understand that custom I the extension universal email around the CSS Formbuilder to use correctly?
Yes, you will need to use Universal Email in addition to CSS Form Builder to send emails from forms.
Hello,
Property with universal email form for my contact to run gotten.Now the same error as usual also ReferenceError comes: reference tons undefined property “fieldName”. This error message comes all thing only with the production of contact contacts. Furthermore the preview generally does not go, to hooks is however set.
Regards
Ps.: Sorry i use World Lingo Translator
I'm sorry, that last message is particularly hard to decipher. Can you try using a different translator and posting it again?
