Basic error uploading images
Thread begun 5/11/2010 2:05 am by ffiguerola395137 | Last modified 5/24/2010 11:49 pm by ffiguerola395137 | 4163 views | 6 replies |
ffiguerola395137
After following your instructions (Geting started with Digital File Pro 2) I'v had this error always when I try to upload a file.
"The requested document was not found on this server. "
¿Can someone explain what happens?
I have the following php code in my php page:
<?php require_once("../WA_DigitalFilePro/HelperPHP.php"); ?>
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../images/",
'FileName' => "".((isset($_FILES["Uploadfile"]))?"Uploadfile":"") ."",
'DefaultFileName' => "",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["submit"])){
WA_DFP_UploadFiles("WA_UploadResult1", "Uploadfile", "0", "", "false", $WA_UploadResult1_Params);
<?php require_once('../Connections/fundacion.php'); ?>
change:
'FileName' => "[FileName]",
ffiguerola395137
  change:
************** DONE **********
******* SAME ERROR APPEARS ****
Not Found
Web Server at fondoaliciapueyo.org
please post a copy of the php page in a zip archive so I can examine the entire page, also provide a link.
ffiguerola395137
documents you asked for
The address of the page is :
Gestfiles.php
the problem is caused by the form tag.
change:
<form action="submit" enctype="multipart/form-data" name="form1" class="form1">
<form action="" enctype="multipart/form-data" name="form1" class="form1" method="post" >
ffiguerola395137
Thank you very much. The problem is solved.
I think the form's (the tag) code should be defined or helped by the utility of Webassist. It's only a suggestion.
