Error in checkout process
Thread begun 5/10/2010 3:13 pm by koneill385535 | Last modified 5/20/2010 9:10 am by Jason Byrnes | 5354 views | 9 replies |
koneill385535
When I finish entering my credit card and shipping information in the checkout process and push submit, I get this error:
Fatal error: Call to undefined function curl_init() in C:\xampp\htdocs\ePerfusion.com\WA_eCart\WA_eCart_FedEx_PHP.php on line 140
What does this mean and what can I do to fix it? Do I need to have my Authorize.net information all entered (I don't)?
Open the php.ini file in the C:\xampp\php folder, and find the following line:
;extension=php_curl.dll
remove the semi colon at the beginning of the line to uncomment it:
Then restart the Apache server.
koneill385535
OK, now it says this when I finish the confirm page:
Unknown column '5167c50f44e90c412a448dc6111580e5' in 'where clause'
Where should I look to fix that and what should I do?
the store order summary or store order details behaviors on the confirm page are storing the session ID value in a column that is numeric
Most likely it is in the Store order summary behavior.
Double check the store order summary behavior for the column that is bound to the session ID. Make sure the data type is set to text.
you will also need to update that column in the database to make it a text column.
koneill385535
Hmm, where is the store order summary behavior?
The store order summary and store order details behaviors are on the confirm page.
koneill385535
I meant where on the confirm page do you change this? Is it supposed to be one of the server behaviors? I can't figure out where to change it.
Yes, the store order summary is a server behavior.
In the server behaviors list, double click the store order summary server behavior to edit it.
koneill385535
Well, it sounds like that is my problem. I don't have that in my server behaviors panel. How can I add it?
login.php
