PowerStore3 installation
Thread begun 5/10/2010 11:56 am by rmtoelle346587 | Last modified 5/11/2010 11:05 am by Dani Chankhour | 2607 views | 4 replies |
rmtoelle346587
Does PowerStore3 have its own PHP built in? What is the process to install PowerStore on windows server 2003 R2 32bit OS. I have PowerStore3 running on Windows Vista PC with XAMPP. I want to transfer everything to our main server, come to find out it already has SQL Server 2005 already installed, will I need XAMPP? Or can I install powerstore in our website directory/order and use SQL Server 2005 for the DB. I already exported the SQL DB file from XAMPP and saved it to upload to the main server along with all the PowerStore3 files.
Will I still need cURL? as well? I tried to load XAMPP and got conflicts with SQL Server 2005, the ports that it uses is 80 which is the same as XAMPP. this is getting confusing to me, I am a novice for sure.
Please help, I have been working on this for a month now. I dont want to have to start over to install it all on the server. It was hard enough to configure on my Vista PC, I never did get Pay Pal to work or Fed EX.... thanks for any help you can give me
Dani Chankhour
PowerStore does not wok with SQL Server 2005.
is your windows server going to be your live server?
rmtoelle346587
PowerStore does not work with SQL server
OK, so now I am stuck... again, what is the process to install Powerstore on Windows Server 2003?
rmtoelle346587
Live server
Yes Windows 2k3 is live server, whats next step? How do I get the XAMPP to work, or is there another program to use for W2k3? What about PHPmyadmin? do I need that, and cURL?
This is getting ridiculous for me to figure out, I am just trying to install the program on the server, I have to get this running... soon
Dani Chankhour
You can try installing PHP separately.
here is a link that i found that includes the steps you need to take to install PHP:
php2003/
PHP/
We also have a document that is for xp and vista but you might use it as a refernce:
web_dev_begin.pdf
next you would want to install mysql:
watch?v=1uYmkKU4ai0
