Problem with orders en orderdetails
Thread began 5/10/2010 8:56 am by fidelis331565 | Last modified 5/11/2010 10:24 am by Dani Chankhour | 1425 views | 4 replies |
fidelis331565
I created a shop in ecart5, it works fine, I thought. I must do something wrong, because when I tested the shop by buying a product and made the payment, it works well. Then I login again and want to buy the same product, the old order and orderdetail will be rewritten in the database. Instead of 2 orders there is only one. The orderdetail get a new ID and the old is deleted. All data is updated. The order ID stays the same. I put the shop behind an inlog. I tried everything last 2 days, In the cart I changed in the bindings; ignore, add new, and replace. Checked the DB, checked in confirm the order en orderdetails. I just bought ecart5, 1 week, please help.
Dani Chankhour
Try clearing your cart on the success page by clearing out the session. It looks like the old transaction id is being used for the new transaction.
fidelis331565
Tried with success page, but order will be re-written
I tried but it does not work, I changed the redirect straight to the success page (No paypal) and still the order and orderdetails are re-written. I still think I do something wrong, I will create a new shop, maybe then it will work.
fidelis331565
It´s working, but...
Problem is solved, the session is ended, but also the login session. I have read some treads about this, but the code I used does not keep the userID session alive:
Code:
// Initialize the session.
// If you are using session_name("something"), don't forget it now!
session_start();
//store the user session
$userSession = $_SESSION['UserID'];
// Unset all of the session variables.
$_SESSION = array();
// If it's desired to kill the session, also delete the session cookie.
// Note: This will destroy the session, and not just the session data!
if (ini_get("session.use_cookies")) {
$params = session_get_cookie_params();
setcookie(session_name(), '', time() - 42000,
$params["path"], $params["domain"],
$params["secure"], $params["httponly"]
// Finally, destroy the session.
session_destroy();
unset($_SESSION);
session_regenerate_id();
//reset user session
$_SESSION['UserID'] =$userSession;
I use Security Assist.
Dani Chankhour
I'm glad you were able to resolve the issue and thanks for posting back with the solution.
