Can't display more then 1 graph??
Thread began 5/07/2010 8:23 am by iamdan356160 | Last modified 5/12/2010 10:43 am by Jimmy Wu | 2829 views | 8 replies |
iamdan356160
Are you able to display more then one graph on the same page?
I've tried it (with 4 graphs), but 3 of them will not display and are acting as though there is a broken link... but all files have definitely been uploaded to the server!!... Check it out...
graphexample.php
...Any ideas?
Jimmy Wu
There shouldn't be any issues with having more than one chart on a page. Can you zip up these two files and attach it in your next response?
/DynamicWebCharts/Data/graphexample_dataparser4.php
/DynamicWebCharts/Data/graphexample_dataparser1.php
iamdan356160
Thanks for the quick response... Here are the files...
Data.zip
iamdan356160
Any ideas??
Jimmy Wu
Sorry, you responded late on friday and our support hours don't run on the weekends. I didn't see any issues with those files, can you also send these files?
/DynamicWebCharts/Data/graphexample_data4.php
/DynamicWebCharts/Data/graphexample_data1.php
iamdan356160
Here you go... Regards.
Data2.zip
Jimmy Wu
It appears that the graphexample_data4.php file's header was written incorrectly. The first line of that file looks like this:
<?php echo "<" . "?xml version=\"1.0\" encoding=\"utf-8\" ?".">"; ?><?php echo "<" . "?xml version=\"1.0\" encoding=\"utf-8\" ?".">"; ?><!DOCTYPE wa_dwc SYSTEM "wa_dwc.dtd">
It should look like this:
Try replacing that first line in the graphs that aren't displaying correctly and see if that causes them to work.
iamdan356160
I'm afraid that didn't fix it! :(
Any other ideas?
Jimmy Wu
Can you send me the updated files so I can verify the changes just in case?
