submit button in ie7
Thread begun 5/06/2010 6:40 pm by aaron322044 | Last modified 5/12/2010 10:34 am by Jimmy Wu | 3916 views | 7 replies |
aaron322044
I have a search form that in IE7 shows up with no results if pressing enter, yet works fine when clicking mouse button. The url that shows up when clicking mouse is
/reverse_results.php?S_num=&S_phone=555-555-1212&Search.x=36&Search.y=7
but when pressing submit it shows up as
Please advise, thanks.
Jimmy Wu
Do you have a url where we can see this behavior?
aaron322044
url
reverse_search.php
In Internet Explorer, 6, 7 or 8
first type in 732-905-0898 and press enter. You will not get results. Then do it again and click with mouse, and the results come up.
Thanks.
Jimmy Wu
This is an issue with IE and having only one form element. If you add an additional form element and make it hidden, the value should be posted and you should get results.
aaron322044
Thanks for your reply. I allready have one, see below
<form action="reverse_results.php" method="get" name="WADASearchForm" id="WADASearchForm">
<table border="0" align="center" cellpadding="0" cellspacing="0" class="WADADataTable"><tr>
<th class="WADADataTableHeader"><div align="center"><span class="WADADataTableCell">
<input type="hidden" name="S_num" id="S_num" value="" />
</span>Use - between numbers</div></th>
</tr>
<tr>
<th class="WADADataTableHeader"><div align="center">Phone:</div>
<span id="sprytextfield1">
<label>
<input name="S_phone" type="text" id="S_phone" title="example 718-555-1212" value="example 718-555-1212" size="25" />
</div>
</label>
<span class="textfieldRequiredMsg">A value is required.</span><span class="textfieldMinCharsMsg">Enter in this format<br />
718-555-1212</span><span class="textfieldMaxCharsMsg">Enter in this format<br />
718-555-1212</span></span></th>
</tr>
</table>
<div class="WADAButtonRow">
<div align="center"><span class="WADADataNavButtonCell">
<input type="image" name="Search" id="Search" value="Search" alt="Search" src="WA_DataAssist/images/Pacifica/Ultramodern_search.gif" />
</span></div>
</div>
</form>
Jimmy Wu
I looked up the error and it appears that the second input has to be a text input but displayed as none:
form-submit-by-enter-key-and-internet-explorer/
aaron322044
Thank you! Worked perfectly.
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
