SA access pages manager not working
Thread began 5/06/2010 8:11 am by jeffmg279672 | Last modified 5/06/2010 12:26 pm by Jason Byrnes | 1135 views | 3 replies |
jeffmg279672
Intel MacbookPro, OS10.5.8, DMW8.0.2, SecurityAssist 1.1.8.
Trying to set up access restrictions on a group of pages but not having much luck. I select the pages, apply the rule, indicate the redirect page and hit OK and get the following two messages:
I've tried replacing the SecurityAssist_Object.js file in case that was causing the problem, re-started DMW and started over, but same thing happens... any ideas what's going on here?
what is the extension of the files you are trying to protect?
Security Assist canonly be used to protect PHP ASP or ColdFusion pages, judging from the first error, you are trying to protect a file with an unsupported extension.
jeffmg279672
They're all PHP pages... so I can't secure them using SA, is that right? No way I can change them as they're dynamic pages...
it should work for PHP pages.
login.php
