powerstore2 Call to undefined function imagecreatefrompng()
Thread began 5/05/2010 2:34 pm by arkin377152 | Last modified 5/05/2010 6:25 pm by Eric Mittman | 1167 views | 1 replies |
arkin377152
Trying to create products and during image upload process get error:
Fatal error: Call to undefined function imagecreatefrompng() in /var/www/smithcorona/WA_DigitalFilePro/HelperPHP.php on line 840
The images do get to the Images/Upload directory (where permissions were set so the apache userid owned that directory and had RWX permissions.
Same thing happens with other image formats (just slightly different line number).
These functions should be defined by the gd module within PHP. You will need to ensure that you have the gd module enabled for php on your server. You can check the status of the gd library by creating a php info page. This is any php page with this line of code in it:
<?php phpinfo(); ?>
You should be able to see gd listed in the extensions along with the details about the version. Without this extension enabled you will get this error any time you reference these functions or others that are included in the library.
