WAeBayStoreBuilder Doesn't Install
Thread begun 5/05/2010 5:19 am by dvmarion144484 | Last modified 5/21/2010 11:47 am by Jason Byrnes | 2554 views | 4 replies |
dvmarion144484
I tried to install "WAeBayStoreBuilder102.exe" but I receive an error message stating that the product cannot be installed without Macromedia Contribute 3 being installed. I have Macromedia Contribute 3 installed on my system. Yet, each time I have attempted this installation, I get the same message. What can I do to get this application to install correctly?
TX!
David
This is a problem with the registry value that we are checking to determine the Install Path of contribute. You will need to edit your registry to put the value in that we are checking for.
1) go to the Start Menu -> Run
2) Type "regedit" and click OK.
3) Expand My Computer -> HKEY_LOCAL_MACHINE -> Software -> Macromedia -> Contribute -> 3 -> Installation
4) Note the value of InstallPath. if you installed Contribute to the default location it will be:
C:\Program Files\MacromediaContribute 3\n5) Select the Contribute key on the left hand side and right click it. Select New -> Key. name the Key "3.0".
6) Right Click on the 3.0 key and select New -> Key. Name it "Installation".
7) Right Click on the Installation key and select New -> String Value. Name the string Value "InstallPath"
8) Double click the InstallPath string value and set it to the path that was noted in step 4. if you installed Contribute into the default location, it will be:
dvmarion144484
It Works
After following your clearly detailed steps, I ran the "WAeBayStoreBuilder102.exe" application again and it completed successfully.
TX!
dvmarion144484
404 Error while attempting to contact Webassist Site
After successfully installing the eBay StorewBuilder extension in Contribute 3, I attempted to connect contribute to my account on ebay. While processing the information requested I received a 404-Error code while attempting to access the "www.webassist.com/ebaystores" page. What can I do now?
the eBay Store Builder extesnion was discontinued over 2 1/2 years ago, and is no longer supported.
We offer support for discontinued products for 1 year after they are discontinued.
