Overflow of text
How do I remove the extra text that comes on the bottom of the maps?
If you go to test.php and scroll to the 2nd map, it overflows onto another <div>
Can this text be shortened / removed?
I'm not sure that its allowed to remove or modify that text since is looks like its the copyright information and terms of use.
There has to be a way. Sometimes in a map it is included and cut off at the border of the map and others it overflows.
Go to index.php
Scroll down to "Stir" and "49 Grove" and you can see the different widths of the text within the pro google maps. There has to be a way to keep within the borders...
Do you have an example of a map where its cut off? It looks like the text overflows in both the maps on your page.
