Remove the bubble
I saw the thread about removing the bubble bust doesnt seem to match up to the .js I have.
Can someone please give me a clear instruction on how to remove the bubble on the map?
Thanks.
Thanks.
please post a link so I can see your JS and I will happy to help.
Are you using "click" or "mouseover" as the action to display the bubble? If you are using mouseover, you will need to create an action to close the bubble after the mouse moves away...
Not necessarily, you can remove the code that pops up the bubble and the bubble will not pop up at all.
Sorry. I would have thought that was obvious. I'll read more carefully next time... :-0
