On Insert, can I have an "if" statement for value?
Thread began 5/04/2010 11:08 am by dinohorn397192 | Last modified 5/05/2010 1:08 pm by dinohorn397192 | 1224 views | 2 replies |
dinohorn397192
During the last step on the "Insert Record Wizard", I can echo php code as values. My question is, can I go a step beyond that and have an "if" statement as a value.
<?php if($_POST['realvacdate'] != '') { echo $_POST['realvacdate']; } ?>
When you bind to a form element in the insert behavior, the code entered by default is sort of shortened if statement called a ternary expression.
the code will look similar to:
<?php echo((isset($_POST["realvacdate"]))?$_POST["realvacdate"]:""?>
The long form using an if statement for this would be:
if(isset($_POST["realvacdate"])) {
    echo(
$_POST["realvacdate"]);
} else {
    echo(
you could modify the ternary expression to also check for a blank value:
<?php echo((isset($_POST["realvacdate"]) || $_POST["realvacdate"] != "")?$_POST["realvacdate"]:""?>
you can also further modify this expression to use something besides a blank string if it is false:
<?php echo((isset($_POST["realvacdate"]) || $_POST["realvacdate"] != "")?$_POST["realvacdate"]:"This is my false value"?>
dinohorn397192
I appreciate the explanation. I'll be implementing this in my forms tonight.
