Manage Relational Tables: Relational Table Not Updating
Thread begun 5/25/2009 1:45 pm by Nigel | Last modified 6/02/2009 5:50 am by Ray Borduin | 5103 views | 6 replies |
Nigel
OK, after burning up way too many hours on this, I give up, I cannot get the MRT behavior to work. I'm trying to update the itemcolors table, which is a lookup table for my product options, linking ItemID to ColorID. I added the product options using the Insert Multiple Records behavior, that worked fine. Now I need to offer the ability to update that table, so after updating all other fields (product name, description, image, etc.,) the ItemID is passed in the URL to the item-update-options.php page.
STEPS. I created a checkbox list, bound the variables from the colors table, and applied a repeat region driven by a recordset from the colors table. I then applied the MRT behavior using the ItemID from the URL ($_GET['ItemID'] as the key value.
RESULTS. The checkbox list displays correctly, all the options are displayed and only the ones in the lookup table are checked. However, if I check or uncheck any options and submit, the page reloads (no redirect specified) and the original options are restored, i.e., the lookup table is not updated. I removed everything and started from scratch multiple times, I don't know what I'm doing wrong.
BTW, I've used the MRT before on another site and after a brief struggle I wrestled into submission. I've compared the code and the only differences I can see are that I previously used a session variable for the key value in step 2 of the wizard; and there is no repeat region outside of the DA repeat selection behavior, whereas in my current page DA left my repeat region and inserted it's repeat selection inside of it.
[Code removed for brevity.]
Nigel
Solved
The page I used for the MRT was the item-update.php page re-purposed. I thought some old code in there might have been causing problems, I had taken out all the old server behaviours, but had left a bit of code debris in the HTML, specifically a redirect on the FORM and a hidden update field. Now the page seems to work. Just need to add another checkbox list and MRT and I should be good.
Nigel
Two Manage Relational Table Server Behaviors in One Form
I added in the second checkbox list for sizes, and added a second Manage Relational Table server behavior, but no luck. The sizes display fine with the correct checkboxes checked, but changing them and submitting does not update the database. The first MRT for colors still works.
Do I need to do anything special to have two MRTs working on one page? They're both in the same form, the first MRT does not redirect, only the second one. The first is triggered by the button, the second by any form submission.
Incidentally, I could not apply the second MRT to the page properly, it added the server-side code to the top of the page but it did not make any changes to the HTML, my repeat region with the checkboxes. I had to copy the code for the checkbox list from the first MRT and alter it for the second one. Not sure if that's a bug.
Code Attached.
Appreciate any clues.... thanks!
It is difficult to debug something this complex without looking at the code and testing it in context. I have never used two MRT Server Behaviors on the same page, but I don't see why it wouldn't work.
It could be the position of your recordsets, code, or something else entirely... it is just too hard to say without debugging it working.
Nigel
Thanks Ray. I'll check out the order of the code, maybe switch it around a bit. I'll also try using two forms and having the one submit after the other is fired. Will post back if I have any success. I really don't want the user to have to go through two steps to change each option.
Nigel
Hand Code Fix
OK, it seems like DataAssist is broken when it comes to adding two MRTs to one page. I could not get it to work through the WA interface. No problem applying the first MRT to a checkbox repeat region; but when I applied the second one the head of the document was updated but not the checkbox HTML in the body. I finally got the page working by copying and pasting the server-side code at the top and in the checkbox repeat in the body for the first region and then modifying it line by line. I hope this will be fixed, it's been a complete time-waster, and yet IMO it's one of the most useful server behaviors.
Thank you for the feedback. Please post a support incident with a full description of your use case.
I don't think we test for multiple MRT server behaviors on the page and it sounds like there is a bug there.
Thank you for bringing this to our attention.
