data base manipulation
i have error message wa_getdocumentdom is not defined when store cart summary in database dialog box open.
If you are getting this message when applying the eCart server behavior or editing it there might be a problem with the cache file. Here is a link with steps for deleting this file to get past these types of errors:
Please give this a try, if it does not work for you then there might be a corruption of the configuration folder. Here are the steps you can take for that if it is the case:
showpost.php?p=12293&postcount=2
Please post back and let us know if the issue persists.
i just rollback ecart whole package to my previous version 3.6, everything just ok, since i have problem when i update the ecart to 3.7
