Syntax Error - Please help!
Thread begun 5/02/2010 10:11 pm by brockfam5387000 | Last modified 5/03/2010 10:03 am by Jimmy Wu | 1340 views | 1 replies |
brockfam5387000
This is the error i am getting when I go to the php page
Parse error: syntax error, unexpected ')' in /home/content/m/i/k/mikebrock/html/register.php on line 422
Attached is the php file
can anyone help?
Do you need anything else to check it?
Mike
Jimmy Wu
It looks like something wasn't applied right this time when you ran through Form Builder. Try removing the form completely and re-applying it to the page. The 3 if statements at around line 422 should be similar (not exactly the same) as this:
if (ValidatedField('untitled1','untitled1')) {
if ((strpos((",".ValidatedField("untitled1","untitled1").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
Instead, your form was applied without the if statement check like this:
if (ValidatedField('register','register')) {
if () {
if (!(false)) {
