Custom designs
Thread begun 5/02/2010 8:08 pm by jebrandon343719 | Last modified 5/03/2010 12:25 pm by jebrandon343719 | 2173 views | 2 replies |
jebrandon343719
Custom designs
Hi, I love this product, however would love even more if I was able to create my own designs - is this possible?
What options do I have to change the look of the gallery in a webpage?
Justin Nemeth
Each gallery design is in the galleries folder. If you want to make you own, you can just duplicate one of those folder as a starting point, then edit the files as needed. You will see various php, js, and css files for the gallery. The other thing you should do is edit the admin/design.xml file to give it a custom name. Basically, every folder it finds in galleries can be usable as a design assuming it follows the correct structure.
There should be some other posts in this forum that can give you more details that will help out making a custom design.
-justin
jebrandon343719
Thansk - I will give it a go
