Restore PS2 DB Import error
Thread begun 4/30/2010 3:49 pm by msjj000 | Last modified 5/03/2010 7:18 am by Jason Byrnes | 2275 views | 2 replies |
msjj000Beta Tester
Hi WA,
I have had to move my live store and I have made backups of the database as I normally would. When I restore I get the following error and only half the products are loaded and the user table isn't loaded at all. The other tables appear to load ok. I can restore an earlier backup unfortunately its a month old and missing rescent sales, user data etc.
I'm running MySQL v5.x. It is PS2 with PowerCMS tables.
MySQL said: Documentation
#1064 - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '&phpMyAdmin=e29fdd1e0a5d3b84d3d60095a7e6f9b9 '<p><span style="font-size: 12pt; f' at line 4
Can you point me in th eright direction please?
Thanks, Mark.
msjj000Beta Tester
I grabbed the older database and extracted the products table and then imported it. The same error occured. Hope this helps pinpoint the problem although it doesn't get me live again.
somewhere in your restore script is the following value:
that is causing the error.
look for that value in the restore script.
