CSS not immediately visible on page load
Thread begun 4/29/2010 11:49 am by public376315 | Last modified 4/29/2010 12:24 pm by Jimmy Wu | 1296 views | 1 replies |
public376315
I recently used CSS Sculptor to create a quick website (www.tidegadget.com), and I noticed that in IE7, when loading the first page of the site, many times the content appears without any CSS for a split second before the CSS goes into effect.
Is there a known issue, or reason, for this CSS lag? I've created many a site before, most heavy with CSS, and have never run into this CSS display lag. Does it have something to do with the particular CSS used by CSS Sculptor?
Thanks in advance!
Jimmy Wu
I just tested this and it does look like the page I generated in sculptor also has that lag. The reason for this is the way the style sheet is imported. It is using the @import url call to import the style sheet. If you use the link method to include the style sheets that are needed, the css will load right away. For example, this is how Sculptor generates it:
<style type="text/css" media="all">
@import url("CSSSculptor/1ColumnFixedCentered_CaboSunset_css/screen.css");
</style>
You can add this into the body tag for it to load instantly:
<link rel="stylesheet" type="text/css" href="CSSSculptor/1ColumnFixedCentered_CaboSunset_css/screen.css" />
