map not shown in all size choose
Thread begun 4/29/2010 9:05 am by fredalva299199 | Last modified 5/06/2010 7:15 am by Jason Byrnes | 4566 views | 6 replies |
fredalva299199
i just setup google pro maps and define area as 600X400.I use dynamique address and map is not show in all area define in script.
Is someone have same problem ?
Fred
please post a link where i can see the problem to investigate the cause.
fredalva299199
Sorry, this is link:
detail_location.php?loc_id=1
this is an issue with using the map in spry tabbed panel.
to work around the problem, edit the google_javascripts/wagmp_map_1.php file.
find the following code:
var map = new GMap2(document.getElementById('wagmp_map_1'));
and change it to:
var mapElem = document.getElementById('wagmp_map_1');
var mapWidth = mapElem.style.width;
var mapHeight = mapElem.style.height;
var map = new GMap2(document.getElementById('wagmp_map_1'),{size:new GSize(mapWidth.replace('px',''),mapHeight.replace('px',''))});
fredalva299199
Thanks works now, but i can't edit map to update something in dreamweaver.I click on map but no edit buttun in propertie panel.Is there because map are in spry tab ?
Other problem if i set driven option with dynamic value there is nothing shown in livesite.
Fred
fredalva299199
No answer ?
login.php
