Problem using UE v4
Thread begun 4/29/2010 6:53 am by info72555 | Last modified 4/29/2010 8:26 am by Jason Byrnes | 1397 views | 1 replies |
info72555
Problem using UE v4
Your videos make setting up your extensions so easy... I am not a programmer, the reason I keep purchasing your software. Needless to say, it's a bit frustrating if things don't work so please help :o)
I set up a VERY simple form in FormBuilder and have added the UE email functionality as per your instructions.
A question: once UE 4 has been set up - is there an easy way to edit existing settings? All the settings were wpied out when I opened UE 4 in the same form.
I am getting the following error message:
Fatal error: Call to undefined function: session_commit() in D:\sitedata\hepout\Inetpub\wwwroot\new\Contact.php on line 61
PHP Fatal error: Call to undefined function: session_commit() in D:\sitedata\hepout\Inetpub\wwwroot\new\Contact.php on line 61
The code for the form is attached
try changing:
session_commit();
session_write_close();
session_commit(); is an alias of the session_write_close(); that should be defined on all servers, but in some cases, the alias will not work.
to edit an existing instance of universal email, open the server behaviors window, window -> serve behaviors) and double click the universal email server behavior.
